A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 698
Butcher supply wants to replate meat market equipment
(1996)
Hi, Everyone
I am interested in learning to replate used and worn-out meat market equipment. Such as meat grinder heads, meat saw wheels, etc. The materials and process will need to be "USDA APPROVED." I believe the materials used for this type of work are either nickel or tin. I will be needing a supplier of equipment, materials, and training.
Thanks, Donny
Donny Rodriguez
- butcher supply
Donny, I would agree with you that tin and nickel sound like probable coating materials for food equipment. You'll probably also want to look into electropolishing of stainless steel.
Plating, much more so than most businesses, is 'jobshop' oriented. So I'd suggest that you could start by becoming an expert in writing specs for refinishing equipment in this market,finding plating shops who will do the actual plating for you, and supervising the Q.A., leaving in-house plating until later if ever.
Electroplating Engineering Handbook
Very few manufacturers, even huge ones, do their own plating in-house anymore because plating will involve you in EPA and OSHA regs for air and water pollution control and solid waste management. So maybe start on the marketing end, and move to the actual manufacturing side only if and when you need to and have enough experience to stay out of trouble? Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
