netneut
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
Finishing.com has been free for 22 years,
but without net neutrality we could soon
cease to exist. Do us a solid, click on
the banner, and contact congress today!
HomeFAQsBooksHelpWantedAdvertiseForum
topic 690
Plating steel rod with copper for solderability
(1996)
I would like to deposit a thin film of tin or copper on a steel rod. My problem is the following: I need to solder 18 gauge steel wire on a printed circuit board (PCB) with ordinary solder (made of tin and lead).
There exist a kit in store to do tin plating. But the problem is it is a chemical process with a special lamp. Does anyone have a solution with electricity. As an example 2 electrodes with a DC power supply. One electrode would be tin and the other would be steel rod with every thing soaking in an acid. Is it possible?
Alain Boutin
- Montreal, Quebec, Canada
(1996)
Alain,
You may first want to check with wire suppliers before bothering with plating your own, as tin plated, steel wire may be commercially available. If not, I would recommend the use of an immersion plating solution to deposit the tin. This would require a cleaning, activation and simple immersion, eliminating the need for a rectifier and anodes, etc. One type of immersion tin is available from Electrochemicals in Maple Plain, MN.
Keith Wicklund, CEF-SE
avionics - Minneapolis, Minnesota
\1
Thanks Keith. I'll look for that solution
Alain Boutin
(2000)
Just a note to this process, For cost reduction I think you should look at epoxy glue, a low cost alter is from Noelle Industries Inc. in Mass. They have a low cost epoxy that you could dip the amount of area with either silver or nickel epoxy and depending on the vis and if you wanted it bonded to the PCB this can be done even at room temp cure.
You can still get the steel wire plated depending on the length, but I think you should look at this option especially for bonding to the PCB.
Stephen Bradley
- Ottawa, Ontario, Canada
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
