A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 677
Plating barrels are getting plated
(1996)
Q. Currently in my barrel plating line we are having some problems because the polypropylene cylinders are getting too much metal and the parts inside are coming out with low thickness (the metal supposed to be deposited on the parts is deposited on the cylinder); we are plating copper parts with a tin/lead layer using methyl sulphonic acid in the plating bath, does anyone have any suggestion on how to eliminate this problem or reduce it? thanks in advance for your valuable help.
Luis Moreno
captive plater - Jalisco, Mexico
(1996)
A. I've seen this problem before. I think an easily deposited metal like tin gets the whole thing started then everything starts to plate out. Tin salts cling tenaciously to just about everything. We get it with barrels that go through multiple processes (cyanide copper, electroless nickel, gold, silver).
The only thing to do is chemically strip the metal deposit off before it gets too thick and hope that it doesn't come back.
bill vins
Bill Vins
microwave & cable assemblies
Mesa (what a place-a), Arizona
(1996)
A. Luis, Try stripping the metal out of your barrel and then look at the inside surface. You probably have millions of tiny scratches and nicks. These sites will start plating for a multitude of reasons. contact your barrel manufacturer for his recommendation on how to smooth it out. Also check your hole size. Plastic will peen over the inside edge of the hole to reduce the effective hole size. You may have to drill or ream the holes out so you can get more solution turnover in the barrel.
March 28, 2013 -- this entry appended to this thread by editor in lieu of spawning a duplicative thread
Q. Dear sir,
I find here some trouble in my barrels which I use to do zinc plating on fasteners, as there is deposition of zinc on the outer surface of barrels.
Please help me to sort out the problem as required.
VINKUSH SHARMA
fasteners - Haridwar, Uttrakhand, India
April 3, 2013
A. Hi,
Clean the drum barrel in nitric acid, and rinse in clean water so are sure that's is no nitric acid left. Because I think you have many Iron contamination from the part you drumming in the plastic in the drum.
anders sundman
Anders Sundman
3rd Generation in Plating
Consultant - Arvika, Sweden
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
