A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 660
Fatigue strength reduction from sulfuric acid anodizing
(1996)
Dear Fellow Finishers:
While I believe it is generally known that sulfuric acid anodize will/may cause a reduction in the fatigue strength characteristics of aluminum alloys. I would appreciate it if someone could supply me with an actual reference which documents this. A reference with test data would be even more helpful.
Thank you in advance for your help.
Blair Smith
aerospace - Windsor Locks, Connecticut
(1996)
Blair, Check out "The Technology of Anodizing Aluminum" [link is to info at Amazon about the book] by Brace and Sheasby. Also look at volume two of "The Surface Treatment & Finishing of Aluminum and its Alloys" by Wernick, Pinner and Sheasby. Mr. Brace is in England. Probably worth contacting if the several references in the two books do not satisfy your needs.
In short, it is a mixed bag with conflicting research. I think that your sister company PWA is close to paranoid about it on vanes, or at least the stripping and preprocessing steps.
I know of no aircraft company that allows sulphuric anodising on critical parts . You would lose the crack detection , and it would be disastrous if used on an assembled part . Think of what would happen to the slip rings on a 23 E 50 prop blade in sulphuric acid .
Dave Brackenridge
aerospace plating - Germiston, South Africa
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
