A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 642
Cleaning contaminated nickel plated pads on PCBs
(1996)
We have a lot PC boards which need rework because the plated nickel pads were contaminated with either copper or nickel oxide. The two-sided boards also have solder plated in different areas. I used 15% HCl down to 1% by volume to remove the oxides and it also dull the reflowed solder to certain degree. Those soldered pads will be solder pasted later for surface mount components and reflowed. Is there any better chemical or solution? I also have a lot boards plated with hard gold which was contaminated with roller streak or fingerprints. Is there any cleaning method other than mechanical abrasion?
Jerry Fang
(1996)
As far as the Ni pads,was the contamination due to after plating or co-deposited during plating? The gold pads can be rubbed with white scotchbrite and or later brush plated. We make this type of repair quite frequently to bare and loaded boards.
Tom Sivula
plating shop - Harbor City, California
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
