-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 606
Chloride contamination in anodizing
Q. We are in the process of developing quality control limits for the water used in surface finishing of aluminum alloys, including 7075, 6061 and 2024. One of our primary concerns is to avoid the formation of chloride induced pits in various processes such as cleaning, anodizing, fluorescent penetrant inspection and wet blasting. Is anyone aware of an established "threshold" or safe chloride ion activity that will not induce pits on brief (4 hour) exposure ? A reference from the literature would be much appreciated.
Thanks in advance for your help,
Blair Smith
aerospace - Windsor Locks, Connecticut
Surface Treatment & Finishing of Aluminium and Its Alloys
Wernick, Pinner & Sheasby
A. Hi,
Call the Materials Laboratory at the old Bendix plant in Teterboro, NJ, It is now Allied Signal Aerospace. Ask for Fred, tell him I said hello.
There used to be a limit on the chromic acid anodizing solution for aluminum and Beryllium of Chloride, 0.2 grams/liter as NaCl and sulfate, 0.5 g/liter as H2SO4. There was also a chloride spec for Martin Hard Coating, but I don't remember what it was.
We did not have any reference to chloride contamination for fluorescent penetrant inspection, we used tap water for all, including the plating shop, for many years.
I was unsuccessful in proving that chloride alone caused etching of aluminum parts, there might be an interaction, or there might be some metallurgical reason why, in the same tank load, we had some parts destroyed by etching, and the others without a trace of a problem. But I can tell you this, in almost every case, the etching started in a blind, threaded hole. We used to wash out the holes with a jet of water, but I am not sure how effective it was. Once the etching started, there was no stopping it.
References which may help:
Techniques for Plating on Aluminum I and II , Nov and Dec, 1969, "Products Finishing" magazine (has quite a few other references). The Dec article mentions hypodermic needle hubs, isn't that your business?
Mil-A-8625 [link is to free spec at Defense Logistics Agency,]E, paragraph 6.4 mentions chloride as a contaminant, no level.
Strategies for electroless nickel plating aluminum, Surfyn, 90, Yarkosky, et al.
Hard anodizing of aircraft fuel metering components, wiesner and meers, 45th annual technical proceedings, 1958, AES.
Good Luck!
P.S.: The Canning Handbook gives chloride limits for anodizing solutions similar to the ones we used at Bendix, since you were looking for references.
tom pullizzi monitor
Tom Pullizzi
Falls Township,
A. Why worry about it? Most references recommend using DI water in a minimum of the anodizing tank and the seal tank. Most places will use it in as many tanks as they can afford. To me, controlling it is a waste of lab time and "another tic to chase" as some of my British pilot friends would say. Avoid the whole mess, use DI and avoid the problems. Your sister company , PWA has some limits, but I will question where they got them from.
thumbs up signJames, but nobody runs a DI unit without some limits on the purity, I suppose we are trying to determine that limit. And like documentation, it's better to have wrong documentation than no documentation, at least you have a target.
A. Tom,
I have been fortunate to have worked at two places with good water and one with unbelievably great water. Also, I have NOT been fortunate enough to have worked at a firm that could afford dialysis or deionization of a chrome anodizing tank. Therefore mixed bed DI makeup water was controlled by conductivity and further analysis was unnecessary knowing input water (average) quality.
The Surface Treatment & Finishing of Aluminum and its Alloys by S. Wernick, R. Pinner, P.G. Sheasby, fifth edition, volume I starting on page 431 lists limits of 0.20 g. as NaCl and 0.50 g as Na2SO4. I have been lead to believe that this is the bible of aluminum finishing, if you can wade thru it.
The Electroplating Engineering Handbook, edited by Larry Durney, fourth edition lists 200 ppm of chloride and 500 ppm of sulfate as limits.
Any anodizer that uses bleed and feed method of controlling aluminum content will bleed out both ions faster than they will come in, if DI is used for water adds, UNLESS you have terrible water and do not properly monitor the conductivity light. My reference is mixed bed resin, 2 to 1, with two units in tandem with a 50 K ohm warning light in between the tanks. We rarely had less than 1 meg ohm water. Obviously, bad water in the last desmut rinse could contaminate the anodize tank in more than bleed and feed would take care of. Extremely high drag out parts without proper dripping would complicate it also. In my circumstances, I did not have this, so testing was a waste of time and money that could definitely be better used in other places.
PS: Never etched or pitted a part in the anodize tank.
Q. HI,
I am trying to find a fast and accurate method for testing Chlorides (ppm) in anodizing solutions, with copper and Al as contamination.
Can you help me?
- Beer Sheva, Israel
May 8, 2013
A. To 50 ml sample, add 10 ml 1:1 HNO3. Now add 5 ml 10% AgNO3 solution to precipitate Cl- as AgCl. Filter through a glass mat in a Gooch crucible (tared) dry the crucible @ 110 C to constant weight, and finish via gravimetry.
dave wichern
Dave Wichern
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
