A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 600
Cooling a hard anodize tank
(1996)
What's a good way to cool a hard anodize tank (temperature about 28 °F., -2 °C)?
Most people seem to run the Freon refrigerant vapor, in lead coils, right through the tank. But I don't like direct refrigeration like this.
What I'd prefer is a chilled water-glycol solution at about 10 degrees F., and an air-cooled chiller. But most vendors are telling me they don't want to run the chilled water loop at below 25 degrees F, -4 degrees C), and I figure we need to be down to about 10 degrees F, -12 C, unless we want the coils to be gigantic.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(1996)
Instead of water-glycol, you could use a water-salt system through a flapped lead coil. This way you can go down to -15 °C. We use an ammonia system to cool the brine, and then is pumped through a 48 meter long coil to cool a 7,000 liters tank between -2 to +2 °C.
Saludos desde Mexico
Guillermo Luna
- Mexico City, Mexico
(1996)
Ted, externally cooled hardcoat anodized tanks make the most sense to me!
1. You can operate with a higher temperature of sulfuric acid than you indicated 10 °F.
2. You eliminate the need for internal coils that take up working area.
3. You eliminate the need for shielding of the cooling coils for electrical insulation.
4. More efficient than coils, especially at low temperatures.
We are currently installing a new hardcoat anodize tank at this moment, to increase our capacity.
Joe Hillock
anodizing shop - Philadelphia, Pennsylvania
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
