A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 590
Can't get sufficient Magnesium phosphate build
(1996)
Is anyone out there experienced in magnesium phosphate? We are trying to phosphate a steel casting but are not having any luck. Our customer requires .0003-.0006 of buildup. When we put this much phosphate on the part, the phosphate builds with large crystals, which is not acceptable. We have tried a grain refiner, which helps keep the grain structure small, but then we cannot get the thickness to build up to .0003" when we do this. When we sand blast the parts, we have better success, but our customer will not pay for this. We have tried long and short HCl acid pickles and tried degreasing the parts to shorten the alkaline cleaner time (supposedly this causes larger crystal growth), none of these have helped. Any help would be appreciated.
Keith Rosenblum
plating shop - St. Paul, Minnesota
Preparation of Metals for Painting
Phosphating of Metals
by Rausch
Are you using a proprietary manganese phosphate? Some years ago when I was with the equipment division of a plating supplier we put several Endurion lines in at General Motors plants, if I recollect properly. As I say, I was concerned with the equipment rather than the process at that point, but you just wouldn't believe the millions of pounds of parts that went through those lines for break-in period protection, year after year. I have to believe the process was satisfactory.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(1996)
Ted
If you did not notice, the question is about Magnesium Phosphating and not Manganese Phosphate and this is a big difference.
A. Concerning your question, you can change the acid ratio of the phosphating bath. Reducing the acid ratio will reduce the coating weight of the result. Another possibility is to reduce the working temperature of the bath.
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
thumbs up signOops! You're certainly right, Yehuda; I'm so unfamiliar with magnesium phosphating that I misread it as manganese phosphating without giving it a second thought. Sorry.
Teds signature
finishing.com
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
