A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 589
Poor adhesion of electroless nickel plating on alloy steel
Electroless Plating
Mallory & Hajdu
Chemical (Electroless) Nickel Plating
G. G. Gawrilov
(1996)
We want to plate a kind of steel alloy (a list of the composition is given below) with electroless nickel but up till now it hasn't been very satisfactory because of poor adhesion. We've tried it with activation in hydrochloric acid 1:1 and afterwards Ni strike for about 3 minutes but that didn't work. We like to have a simple solution. Please give us some suggestions.
C       1.92            Si      0.31            Mn      0.43            P       0.021           S       0.01            Cr      11.5 Ni       4.0            Mo      0.74            Cu      0.115 Al      0.07            Ti      0.03            B       0.0002 N       0.0385          V       3.057           Nb      0.011            Ta      0.005           Co      0.067           W       0.118
It is a sintered steel with a hardness of 58-60 Rockwell.
Waiting for some reply
Anke van Esch
Eindhoven, the Netherlands
(1996)
The trick (one of many) with Chrome bearing Iron is to reverse current in the HCl (anodic) then go into a Woods strike under reverse current as well for 1 minute then switch polarity and strike for 5 minutes. Of course this bath will not last very long due to impurities loading on the reverse cycle, so you must learn how to control these impurities by dummying, feed & bleed, or outright dumping periodically. Works every time...even on Hastelloy. But don't EVER strike your other non-chrome bearing parts in this bath. Use it ONLY for your Chrome/Iron parts.
Good Luck,
Dave
Dave Kinghorn
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
