A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
(current
topics)
topic 542
Rhodium plating isn't sticking to stainless watchband
(1996)
Want to touch up some Rhodium or Gold plated [I'm assuming...] Stainless watch band sections. Gold doesn't seem to stick using a little pen plater and CN based Au solution, is there a method to make it stick, or will Rhodium do better?
Thanks / mark
Mark Fraser
(1996)
The question is not gold vs. rhodium. All platings can be made to adhere perfectly. The problem is that the surface must be made clean and active. It sounds like you're not doing the necessary prep. Stainless is difficult to activate. After cleaning, you need a Wood's Nickel strike before the plating.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(1996)
Um, uh, thanks for the reply. What's a Wood's Nickel strike?
Mark Fraser
(1996)
The pen plater alone won't do the trick. You do need to activate the stainless and use a nickel preplate to get either gold or rhodium to stick.
If you are working with localized areas, we have some tooling and solutions that should do what you need.
Derek Vanek
Independence, Ohio
November 30, 2008
Hi, Mark. Wood's nickel is a high chloride strike designed to activate stainless steel. There are many threads here on that subject. You could start with letter 31138. Good luck.
Teds signature
finishing.com
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
