A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 540
Plating Electroless nickel directly onto aluminum
(1996)
Are there documented problems with application of electroless nickel directly onto 6061 alloy aluminum? The specification Mil-C-26074 [link by ed. to spec at TechStreet] does not have any mention of concerns nor underplate recommendations. We have a customer that objects to our use of Ni over Al. They recommend a copper underplate and a Tin/Lead overplate (fused). What are the benefits to these additional layers and are they worth the additional costs?
Gordy Seppanen
materials engineer - Minneapolis, Minnesota
(1996)
I have seen electroless nickel applied directly to aluminum--without a zincate treatment!--for connector housings. Reports were that it was totally satisfactory, but I never saw lab work verifying the adhesion, etc.
Zincate followed by electroless nickel seems to be the most common approach. I don't know what the advantage of an intermediary layer of copper is supposed to be. We have a few electronics plating gurus hanging around here, and hopefully one of them will chime in.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(1996)
We always use zincate followed by electroless Ni with controlled P.
By the way, MIL-26074 has been canceled. We now use AMS2404 [link by ed. to spec at TechStreet].
Harry Andreas
aircraft
(1996)
Gordy, does your customer object to the use of nickel in the product because of its magnetic properties, or is the customer just unaware of common plating practice? Sometimes you have to spend a bit of time to educate them. Although there are methods to apply copper directly to aluminum--see Durney, Electroplating Engineering Handbook. They require uncommon chemistry and a bit of experience to be successful. If the problem is magnetics, you may be stuck trying to find a process supplier. If not, then take time to educate your customer on common aluminum finishing methods.
Good Luck,
Dave Kinghorn
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
(1996)
The customer objects because they believe that the Ni will crack during temp cycle (-55 to 85 C) exposing Al which will then lead to corrosion of the base material. The product is expected to survive 48 hours of salt spray.
I neglected to mention that we do Zincate the Al prior to Ni application, in fact we typically do a double Zincate.
I have found an internal program that tried Cu over Al and believe that the adhesion of plated Cu to Al is less than that of electroless Ni to Al. Unfortunately they did not document this testing. Any ideas as to where I might find such an adhesion comparison?
Thanks for all the comments!
Gordy Seppanen
(1996)
In addition to the traditional generic zincate, Atotech offers their 'Alstan' tin-bearing pretreatment for aluminum, and Gumm offers their 'Bondal' process. Presumably these companies will be able to present quantitative data supporting their processes as being better than zincate.
Teds signature
finishing.com
Ed. note: Fred Gumm Chemical Co. no longer exists, but the process perhaps can be found at MacDermid.
(1996)
Gordy,
At this location we also double zincate aluminum prior to electroless nickel. I do remember that in one application we followed zincate with a copper strike which had a matching effect on the difference in coefficients of thermal expansion which sound like your customer's concern. I think we looked at it as a cushioning layer. I don't remember the specifics, but I remember doing it. We spoke last year about your zinc phosphate application question.
Bob Denney
avionics Tampa, Florida
(1996)
You may use a high pH electroless on double zincate, prior to ordinary electroless with PH about 4.8. This high pH EN plates a thin layer, protects zincate and gives very good adhesion. Sara
sara michaeli
sara michaeli signature
Sara Michaeli
chemical process supplier
Tel-Aviv, Israel
(1996)
As some people know, I sometimes find an answer looking for a question. I may have found one here.
I was just reading "pretreatment for plating on aluminum using the Stannate process by Jongkind and Seyb, aluminum finishing seminar, vol II, Proc. Conf., St Louis MO, 30 mar-1apr 1982, aluminum assoc. 818 Connecticut Ave, NW, Washington DC USA Met A, 8303-72-0144, 539-549.
It says that improved corrosion might be found by having tin next to the aluminum rather than zinc.
Maybe this would interest you.
tom pullizzi monitor
Tom Pullizzi
Falls Township,
   Pennsylvania
(1996)
If your customer is really serious about this, do some comparative thermal cycling of both products. I doubt if you can beat the alkaline strike that Sara mentioned followed by an EN selected for its ductility and its ability to maintain it for the bath life. Most EN vendors probably will not want to spend a lot of time unless it is a lot of plating. I have seen papers from two vendors that address at least ductility and turnovers. I will put a cup of coffee on an alkaline EN followed by most any EN beating copper.
PS copper migration can cause real problems.
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
