A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 490
Coating materials for geothermal plants (vent gas)
heatbath banner    hill cross banner
(1996)
Q. We are currently searching for candidate coating materials for use in geothermal power plants in Northern California. Of particular concern are the cast steel casings of vent gas blowers which experience severe erosion/corrosion within two years of service. The vent gas is saturated with moisture and has approximately 3-5% H2S, 10-20% H2, 0-20% O2, 5-10% CH4, and 40-60% CO2. There are trace amounts of SO2. Temperature ranges between 170-180° F and flow rate is approximately 1300 cu.ft./min. A small amount of particulate carryover from the plant components upstream contributes to the erosion of the blowers.
Do you know of a product(s) that would perform well in this environment? Should nitriding or perhaps metal spray be considered? If possible, we would prefer to apply the protective coating/ process on-site.
Jim
Jim Hanck
engineers
Electroless Plating
Mallory & Hajdu
(1996)
A. Hi, Jim. For "down hole" applications, electroless nickel plating is extremely popular. This application sounds like it is in a quite similar environment. Good luck.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
