A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
Here
FORUM
(current
topics)
topic 455
Aluminum in thin film seems to be migrating into dendrites
(1996)
We observe a corrosion or stress migration phenomenon in 100 nm aluminum films on different kinds of substrates.
Optical inspection shows metal missing sites with dendritic form. Our assumption is that we have either a corrosion or stress problem in the films, but we cannot find any corrosion products.
Would be glad for any help with this!
Kind regards
Chris
Chris Mueller
Fraunhofer-Inst. for Solid State Technologie - Munich, Austria
(1996)
You did not say if the missing metal/dendritic formation was present just after deposition of the Al film or over time. You also did not mention how the film was applied (wet or vac process).
It is possible that the dendritic formation is due to phase change as a result of impurities present in the original film /solid solution.
The missing metal areas may also indicate surface contamination which could result in lack of adhesion of the Al film.
You can send a sample out for analysis and have a layered ESCA percent assay performed to look for contaminants.
Jeff Albom
- El Granada, California
June 20, 2009
Hi, Chris. Tin electroplating, and many other electroplatings have long been known to grow "whiskers" in a fashion that sounds very similar to what you are seeing in your aluminum thinfilm.
Some keys to fighting whisker growth are reducing the stress and alloying the metal with a small amount of something else so crystal growth is not quite so easy. Good luck.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
