A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 427
How is brushed finish before anodizing done?
(1996)
We manufacture small aluminum enclosures and chassis for electronic equipment. We would like to have a brushed finish prior to anodizing. We have called every metal finisher we can find, but no one has provided an answer.
I think it's done with carbide brushes or a drum sander. Can anyone help?
Ron Laury
The Electronic Workshop
(1996)
As I recall from a sheet metal shop in a company that I used to work at, a large belt sanding type machine that resembles a wood planar was used to give a brushed finish to all flat stock. It also served to "plane" the metal down to a specific thickness. After this mechanical process, any punching, cutting, or bending ops would be performed. I don't recall any full sealed box forms being produced; mostly 19" rack panels (some had wrapped mounting flanges but none were sealed edge
Jeff Albom
- El Granada, California
(1996)
there are several ways brush finishes can be applied depending on the equipment used. there are buffing lathes that can be purchased using a variety of wheels or contact wheels with belts. if there are recessed area's there are a number of hand held tools that can be used. there are many types of abrasives on the market I would suggest calling a 3-m distributor they should be willing to help.
Kent Glover
(1996)
We manufacture custom wall plates and equipment rack panels using the finish you described. The name used to refer the process producing a linear grain "brushed" appearance is "Time Saving". Jeff Albom's description is great. You will have a choice as to the grit of the belt used. We job out all of our "Time Saving". Try contacting machine shops first. Good Luck.
Jon Conger
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
