A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 406
Can we add HCl in a Watts Nickel Bath
(1996)
What are the down sides of using HCl in Watt's bath instead of NiCl2?
If pH is the only problem, can a mixture of H2SO4 and HCl be used without NiCl2? Will it be a less expensive bath? please reply. Thanks. KRM
Kaushik Magiawala
plating shop employee - Gandhinagar, India
(1996)
pH IS the problem. pH is a critical variable in running a Watts bath and the addition of hydrochloric acid in any substantial amount will quickly drop you below the allowable pH. That's why it is a good idea to keep some nickel carbonate on hand (for those times when you drop the pH a little too much with an acid add).
Consider nickel chloride to be a "neutralized" form of hydrochloric acid (chlorides required for anode corrosion) and an additional source of nickel as well.
bill vins
Bill Vins
microwave & cable assemblies
Mesa (what a place-a), Arizona
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
