A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsBooksHelpWantedAdvertiseForum
topic 403
Bar coding for tracking material flow in anodizing shop
(1996)
We have ramped up anodizing production from 1 ton a day to 8 ton a day. We anodize aluminium extrusions from a variety of window fabricators. Our problem is that we simply cannot keep track of all the extrusions that reach our plant. We receive extrusions in a variety of lengths.
Is there some way we can bar code the extrusions so that even after immersion in caustic and acid the bar code stays intact? Alternatively, Is there some way we can mark the extrusions?
Please help, we have many irate customers on our hands who feel their material is being mixed up with others material.
Sanjay A. Bulchandani
- Bombay, India
(1996)
Simple solution . . . in my shop, which runs hundreds of different orders a day, we place computer generated labels on all packages as they are received and entered into our system. The label has customer name, job info & a shop order #.
When we rack the parts we put a slip of paper with the customer & shop order # in a ziplock bag which gets attached to every rack with a nylon tie. This bag & tie holds up fine during our anodize & hardcoat procedure & after finishing, when the job goes to the packing department, the packer knows what they are packing & then relabels the finished packages..
David A. Kraft
- Long Island City, New York
(1996)
Although I am not aware of a bar-code method that can withstand the chemicals found on an anodizing line, I use a system of plastic tags, each with a number on them. The tags are fastened to the anodizing rack and the number on the tag is then recorded on the job ticket. When the parts are unracked after anodizing, we just match up the number on the rack with the correct number on the job ticket. This system has helped us to avoid mixed up jobs. In addition, if your customers will allow it, you might try inscribing the customer name (or first letter) directly onto a non-critical area of the extrusion.
Keith Rosenblum
plating shop - St. Paul, Minnesota
(2004)
Maybe laser marking the part prior to anodize will give the desired result. If the marking is done heavy enough it should still be clear after etch and anodize.
Paul Merwin
- California
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
