A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 376
Mechanical polishing vs. electropolishing of stainless steel
Need an Electropolishing Service?
Please Contact:pointer
--> (1996)
Q. Electropolishing of stainless from our customers' responses are overrated. Our customers never tells us about the cost of electropolishing their products ( I suspect it's a lot). They rather buy our products then have it electropolished.
We do mechanically polished stainless and according to recently lab reports, we now can produce a double-sided True #8 mirror polished sheet (note: NOT A #7 mirror with all the polishing lines) with 0.774-0.997 microinch. This compare to electropolished finishes which typically range in the 2-5 microinch, is a cleaner and superior finish.
In fairness, we have fittings products that are mechanically polished and the labs results were 5.95 microinch higher than electropolish materials, but our materials looks nicer. More or a mirror finish than hazy mirror look.
Michael Liu Taylor
Michael Liu Taylor
   specialty stainless steel distributor
Dallas, Texas
(1996)
A. Dear Mike:
There is a lot of misunderstanding about proper applications for electropolishing.
Electropolishing simultaneously cleans, smoothes, deburrs, passivates, and improves corrosion resistance of stainless steels. Electropolishing offers excellent decorative properties, but its principal strength lies in the other properties it offers for the aerospace, food, dairy, medical, pharmaceutical, bio-pharmaceutical, semiconductor, and other high tech industries.
In general, we agree that mechanical finishing can produce better "mirror" finishes at a lower cost, but mechanical finishing alone cannot match all of the surface enhancements available from electropolishing. Electropolishing competes with mechanical finishing in some areas, but its most important applications are those which are beyond the capability of buffing and other mechanical finishes. Of course, any added cost must be justified by the enhanced properties obtained from electropolishing.
Please contact us by telephone for further information.
Ed Bayha
Charlotte, North Carolina, USA
(1996)
Q. Dear Ed,
I'm sorry if I sounded too blunt, but I was faxed an electropolisher's brochure by my customer.
In the brochure, it stated that mechanical mirror polished stainless ranges in the 4-10 microinch whereas electropolished surface can reach 2-5 microinch. This may be true a few years back, but not today. Our double-side mirror polished sheets actually went below 1 microinch in a recent surface roughness lab report.
Since stainless steel alloy has a self oxidation layer that prevent corrosion & rust and the self oxidation layer is best when surface of the metals is at their cleanness. I questioned whether electropolishing actually adds anything to the natural corrosive resistant properties of the stainless steel alloys.
Perhaps the Specialty Steel Industry of North America or the Nickel Development Institute can shed some light on this subject.
I sent samples to several electropolishing companies for their tests and evaluations, so far we haven't got anything back.
Michael Liu Taylor
Michael Liu Taylor
Dallas, Texas
(2001)
Q. I am using phosphoric acid and sulphuric acid solution for electropolishing of 316 L /LS stainless steel.But the result is very bad, I can't get the bright surface but dull surface! I have already try all the setting (voltage, current density), still can't get the polishing effect!
Why the result is like that?Is that the solution problem?(150 ml water, 300 ml phosphoric acid (85%), 550 ml sulphuric acid)
Chong Cheong Wei
- Penang, Malaysia
(2007)
Q. We want to improve the surface finish of ss-304,ss-409 fabricated equipment of having 800 mm diameter to 3000 mm diameter vessel. How can I do electropolishing in such type of vessel of 800 mm to 3000 mm diameter. kindly guide us
santosh kumar
buyer - baddi, H.P. , India
(2007)
A. You can learn a bit of what you want to know about electropolishing from such sources as the Electroplating Engineering Handbook, gentlemen.
Chong: the two most likely problems are excessive water in the solution and inadequate current density. The etching range is large, the electropolishing range is small :-)
Santosh: It's not impossible to do electropolishing yourself, but it's not easy, and generally after some hands-on training one would practice their skills on expendable parts for a while. You may etch these vessels, which could be a big risk to take. There are companies specializing in on-site electropolishing for situations like this, and you may wish to contact one of them instead. Good luck.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
January 16, 2008
A. Hi.
Only with the correct amount of chemicals can electropolish be achieved. make sure that you are using the correct current density (it depends on the formula), temperature, distance between anode and cathode and enough area in the anode (two times the area of the piece to electropolish)
Diego Barrientos
- Medellin, antioquia, Colombia
November 10, 2010
Q. Dear Diego,
I'm a novice at electropolishing and I'm trying to understand the theory.
Can you please give the formulae for calculating the current density?!
I have seen the current density-voltage curve showing the 3 regions of operation in many scientific papers, but I'm not sure how they arrived at it. What is the formula that has been used?
Vasudha Vasudevan
- Ann Arbor, Michigan, USA
October 31, 2011
Q. We would like to electropolish 400 series ss please advice chemical formulation
Shushil Tripathi
employee - Ghaziabad, UP, India
November 1, 2011
A. Hi, Sushil.
There are at least a half-dozen non-proprietary formulas in use, and each has specific advantages. There are also at least a half-dozen proprietary formulas available. But as mentioned, electropolishing is a reasonably difficult operation to do successfully and posting one of those non-proprietary formulas here probably won't get you any closer to success as you will need to simultaneously control many factors including proper mechanical prep, proper cleaning an pretreatment, water content, local current density, local temperature, dissolved metals, racking so hydrogen bubbles do not interfere with polishing, etc. Can you please describe which, if any, finishing books you have available and exactly what problems you are having so that we can try to steer you towards a solution? If you are starting new, and an experienced electropolisher is not available to help you, you will probably need to go to a proprietary supplier like Metal Coating Process Corp. or Russamer Lab [a finishing.com supporting advertiser] to guide you through the maze. Best of luck.
Teds signature
finishing.com
October 26, 2017
Q. Hello all !
We manufacture metal chairs made of SS frames (grade 202). The size of the model varies from model to model. Let's say 600 x 600 x 800 mm.
As a finishing process, we do manual buffing in 4 stages for every single product. This section is having lot of manpower and the costs are going high.
Main problem- High costs & low productivity.
In this case, is it better to go for electropolishing where I can get the finishing done in bulk? Or shall I continue with the same manual buffing ?
Aim- Mirror finish & High productivity.
376
Sushanth Reddy
- Banglore, India
October 30, 2017
A. Other than a polished finish, you never did specify the surface profile. Electropolishing will achieve good results, but you still may need to prep some areas. There are also some costly big mechanical systems that might work; however, it is difficult to recommend alternatives without knowing more
tony kenton
AF Kenton
Nova Finishing Systems Inc.
Hatboro, Pennsylvania
October 2017
A. Hi. The advantage of electropolishing is generally neither appearance nor economy but a surface with no tooth, which decreases stickiness & contamination, and improves corrosion resistance. Generally these are not very important points for chairs. If most of the welds are hidden under cushions, etc., you may wish to fabricate from pre-polished tubing instead of polishing after fabrication.
pic of Ted Mooney
finishing.com
Striving to live "Aloha"
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
