-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 279
Waste treatment of chromic acid
A discussion started in 1996 and continuing through 2009.
Add your Q. or A. to restore it to the "Current Topics" discussions.
I was recently involved in the treatment of a batch of Chromium. I work in the Waste Treatment Department of a shop which does electroless plating on plastics.
We had some Chromic Acid, which we use to "rough up" the parts that are plated with Copper and Nickel. We put about 500 gal or so of this Chromic acid in our 3000 gal batch tank. We had around 47,000 ppm Cr in this batch. We ended up having to treat this batch with about 2500 lbs of Sodium Metabisulfite. We worked around the clock for about four days and filled over 50 filter press loads. (Most normal batches that we treat only fill 1- 2 filter presses. ) Is there an easier way of going about this treatment?
Also, in the event of leaks which spill significant amounts of Cr (5000 ppm) into tanks containing Cu and Ni, is there a good method of Cr removal? We have to add Sodium Metabisulfite, Sodium Hydrosulfite, and DTC and sometimes still have to run out very slow in order to stay in spec. High levels of Cr get us way behind in the treatment of our other wastes. Do other shops experience these problems?
Thanks in advance to any replies.
D. Burton
I don't know of an easy way to treat chrome. The bisulphite method is probably the least sludge intensive. The problem is that these etches hold a very high concentration of chrome; further, the sludge that they do generate is really gooey glop that is very hard to filter.
The only good side is that it is becoming understood that leaks and unnecessary dumps are not affordable, so that whatever it costs to prevent the leaks and unnecessary dumps looks more attractive every day.
Ted Mooney, Teds signature
Pine Beach, New Jersey
By keeping the pH at 2.3 or below during the reduction process (Cr+6 to Cr+3) will reduce the amount of "sludge".
Chris Willcox
- Dayton, Ohio
That's an interesting assertion, Chris. Thanks! Is there a chemical principle that would explain it? I had always believed in keeping the pH in the chrome treatment as high as practical while still getting complete reduction within the available retention time because it minimizes the release of those smelly and toxic sulfides to the air.
Ted Mooney,
Teds signature
November 20, 2009
I have worked in both a chrome plating shop and at different WWTP treating CR+6. If the pH value is not below 3.0 during the reduction process it will take a huge amount of sodium bisulfite, therefore creating excess solids. After the pH is lowered and bisulfite is added run a check for CR+6. Add just enough bisulfite until you see the pH start to climb. If CR+6 is still present lower the pH back to 3.0 and add more bisulfite. Repeat process until you have completed the CR+6 to CR+3 reduction. After the reduction you will need to adjust your pH value to meet your permit. Even though the addition of acid will create some solids it will be far less than the bisulfite.
Chris Willcox
- Union Grove, Alabama
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
