Q&As since 1989
Seeking info for deep etching stainless steel
I have been looking and asking about what chemical(s) are used to deep etch stainless steel. It seems that the sign industry uses something but I have been unable to get anyone to either provide a supplier of the chemicals or what the chemicals are. I would greatly appreciate any information on chemical etching of stainless steel.I am trying to make a small 1/8"t x 12" x 8" sign using a precut vinyl or sandblast resist. The lettering is weeded (removed) and the vinyl is used as a resist. It seems that something like Hydrochloric acid would work, but am not sure.Thank you in advance
Enrique VegaArtMetal
1996
Sir, I would like to know the chemical composition and method for deep etching of stainless steel plates. thanks you very much for your answer
krishna kumar- Dubai, UAE
Hi,, folks. letters 15151,
12455,
10882, and
7775 talk about the formulations in pretty good detail. letter 1273 does also, but it talks about some other things too :-)
