A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing.
    no popups, no spam
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 0115
Improved process to finish aluminum for vacuum application
A discussion started in 1995.
Add your Q. or A. to restore it to the "Current Topics" discussions.
(1995)
I am looking for methods to finish Aluminum so they may be used as sealing surfaces in Ultra High and Medium Vacuum systems. Because they are used in vacuum systems, they must be cleaned to remove any machining oils prior to use. Presently the parts are finished with sandpaper and 0000 steel wool [linked by editor to product info at Rockler]. The desired final finish is in the 8 range (after cleaning). It appears the parts are being etched, during cleaning, just enough to degrade the finish. The only way to get the desired finish back is to polish the surface with 0000 steel wool. It should be noted that some of the surfaces are at the bottom of dovetail o-ring grooves which can have an entry width of 1/8 inch.
Either a different method of finishing or plating is desired. The present method is too time consuming to be practical. Thanks in advance for your help!
Marty Kangiser
(1995)
I don't know whether it has real applicability to your particular need, but aluminum can be bright dipped in nitric-phosphoric solution to mirror brightness (and commonly is, for reflector use) or it can be electropolished.
Plating is certainly possible, but it sounds like it may be adding a complication factor without addressing the basic issue.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Comment to THIS thread START a NEW threadView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
