Wash primer vs. shop primer
Q. Maybe the web readers can help. I am looking for research, opinions or ANY documentation on the use of organic pretreatment (wash primers) over iron phosphate. I have heard that there is a potential detrimental effect. Thanks.
Dave Wright [deceased]- Mequon, Wisconsin
With sadness we note Dave's passing on Oct. 11, 2013. His longtime friend Anne Goyer offers a tribute to him in The Finishing Touch, Vol. 23 No. 4.
on eBay or Amazon
A. Hello, Dave.
My recollection is to the effect that the wash primer depends on a reaction with the base metal in order to function properly--something I think I read in the 'Coating Clinic' column in "Products Finishing" magazine; but I have no real firsthand knowledge of this.
Such Q&A columns tend to not be well-indexed in the databases for computerized literature searches, and I couldn't find it with the Metal Finishing Information Service CD-ROM, but a manual search should find it. If you have an associate in my area s/he is welcome to spend a couple of hours thumbing through my copies if you don't have a closer source of back issues. But another solution might be to try to contact the column's author, Carl Izzo, a consultant who I believe lives in Export, Pennsylvania. Best of luck.
P.S. to the readers: Dave has written a great series of articles on pretreatment. Please see "The Pretreatment Troubleshooter"
Vinyl Wash Primer on G-90 Hot Dip Galvanized Sheet Steel
Q. We are using a 2 Part Wash Primer Per DOD-P-15328, following hot alkaline cleaning, rinsing, blow drying, as a pretreatment for "dry" non-oiled, non-chromated G-90 Hot Dip Galvanized Sheet Steel, for the application of a military epoxy primer, and ultimate CARC topcoat. This systems is a recommended pretreatment in Mil-Std-193 (which I know has been cancelled). My question - is this an acceptable pretreatment for G-90 zinc coated steel for the subsequent coatings application. In addition what is Mil-P-12879, this was also referenced in Mil-Std-193 as the desired pretreatment? Any and all assistance is greatly appreciated. Thank You. Sincerely, Bob Hathaway
robert hathawaytrucks - Oshkosh, Wisconsin
A. Bob, Though I have never painted hot dip galvanized, I do paint a lot of zinc plated fasteners. If the part does not have a supplemental conversion coating over the zinc, then the wash primer is the way to go. (We also use DOD-P-15328) Your galvanize probably does not have a conversion coating over it.
I do not know of a Mil-P-12879, but do know a Mil-T-12879 as called in 193. I do not have a copy of it as it has been cancelled. However, 12879 cancellation notice refers to ASTM D2092 Preparation of Zinc-Coated (Galvanized) Steel Surfaces for Painting. Depending on your contract, you may still be help to 12879, but the technical information in the ASTM is still a good reference. ASTM 2092 Contains methods A-F for pretreating this material. Method D-Acid-base Resinous Treatment is DOD-P-15328. So again, this points that wash primer is the way to go.
Kelly Draper- West Plains, Missouri
Q. What is G90 HOT-DIP GALVANIZED QIANGZONGLIANG KWZLPlating shop employee - CAI JIA PO July 9, 2008 A. Hi, It means a coating weight of 0.90 ounces per square foot. Regards, ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey Ted can be retained for immediate answers or long term project help |
Primer to powder coat 1008 steel?
Q. We produce small and very easy to break metal parts on steel 1008.
We are etching but the epoxy (powder coat application) and polyester
(top layer & finish) have poor adhesion to the part.
I want to know any process that can help me to have better adhesion for the powder coating.
The process shouldn't include spin or fast spin, if we HAVE to spin the product should be very but very slow.
Manufacturing - Bowling Green, Kentucky
February 10, 2009
A. Most powder coat operations call for a minimum of an iron phosphate prior to paint. You will get better overall results from zinc phosphate, but it costs more to operate. James Watts- Navarre, Florida A. I would suggest that you evaluate a product that is called two pack wash primer in the USA (the one pack version is not for you). You may be able to obtain it from an auto repair shop. Because it contains phosphoric acid its adhesion to metal substrates is outstanding. Mix only sufficient for one day as beyond this time it will jell. It is now considered operator and environmentally unfriendly due to the chromate content but is still sold because there are very few alternatives... also click on the image to the left, you may find an American equivalent to our Anoprime. Terry HicklingBirmingham, United Kingdom |
Dear Sir
I would like to know the difference between wash primer and shop primer and I have another question : what happen to unsaturated polyester in storage if increase in the pot life of the resin or what happen
and also for BPO what happen to it if it lose its effect or the active oxygen lost
wait your reply
thanks
formulator - Sadat, Egypt
August 26, 2009
Wash primer is a special metal primer (contains chromate pigment for corrosion resistance & phosphoric acid to improve adhesion). There is only one specific formula to achieve this. There are many hundreds of formulas to achieve a shop primer. Some shop primers are for wood others for metal & wood. I am not sure what you require for your other Q's.
Powder coating over vinyl wash
Q. Jeff from an iron works in Grassie Ontario Canada. We have had some rusting issues for years with some of our mild steel products. After trying many products an older body man suggested I try " vinyl wash " as a primer. 18 months ago we started to powder coat all of our products. does anybody know or has tried to powder coat over vinyl wash and what was the result. is there a difference between vinyl washes manufactures? If vinyl wash is not the answer does anybody have any better suggestions? thanks in advance Jeff
Jeff Hiltsowner - Grassie, Ontario, Canada
March 24, 2010
A. Dear Jeff. Vinyl wash, wash primer and etch primer is name used to cover the same product. This material was developed by the US Navy around 1940. It is either supplied as a two pack material primer and catalyst or a three pack, primer, catalyst and thinner. Birmingham, United Kingdom A. Corrosion protection on mild steel is achieved by various methods dependent on the environment into which your product goes. ![]() Geoff Crowley Crithwood Ltd. Westfield, Scotland, UK ![]() |
A. Hi. I've heard of vinyl wash primer several times in the "Paint Clinic" column by Carl Izzo in Products Finishing magazine. I think it contained hex-chrome and has consequently fallen out of favor.
