Letter 9024
Removing paint from motorcycle
rims
I have a set of painted motorcyle rims that I want to polish but,
it seems that the paint on the rims is very difficult to get off. I
have tried airplane stripper and other such items but to no avail, I
also tried to sand them which works but is a long and tedeous
process. Is there some sort of chemical that I can use to get this
paint off.
Miles Brown
- Newark, NJ
I ran into the same problem with my rims and tried the same
strippers, and sanding would take a life time for all of them. I
tried sand blasting with sand and it left a pitting that also needed
sanding out. I finally ended up sandblasting with glassbeed that left
the surface smooth before I polished it out.
Nathan Mortenson
- Pacifica, CA, USA
I have just stripped the outer rims on my Kawaski and I used a 3M
stripping tool that attaches to a electric drill. It removed the
paint easy and did not mark the alloy.
Bernard Harrison
- New Zealand
Try sand blasting it. It will take off all layers of the paint and
also take off rust too.
Preston Tucker
- Marietta, GA, USA
I've done my GXSR750 and several of my friends' bikes. It's a pain
but I can almost make look chrome. have to see to believe it. I'll
wash a wheel off and send you a pic. So... get a large can of
aircraft stripper [link is to product info at Amazon]; it's
some nasty stuff so make sure to get a chemical resistant
protective gloves [link is to product info at Amazon] b/c the
stuff will burn your skin. Follow the directions and you'll have a
raw rim, Only do the lip of the rim b/c the spokes have a rough
finish and it looks bad. Once it's COMPLETLY rid of powder coat. Use
very clean,soft cloths,
Mother's Aluminum Polish [link is to product info at Amazon], and
a-lot of rubbing.
David Jones
- Frisco, Texas
HI, I WAS WONDERING WHAT IS THE EASIEST AND FASTEST WAY TO REMOVE
THE PAINT OFF OF MY MOTORCYCLE RIMS. I READ PAINT STRIPPER, AND
AIRPLANE STRIPPER, AND THAT THERE ARE 3 DIFFERENT TYPES OF STIPPERS.
LIQUID, PASTE AND GEL. SO WHICH SHOULD I TRY.
ZACH CHAUDHRY
STUDENT - TUCSON, AZ
Dear Reader, please --
- Post a
question on a different
subject.
- Answer or follow-up on this
subject (in non-commercial
fashion).
