No popups, no spam.
Folks helping folks with
respect.  You'll like it.
  HomeFAQsBooksHelpWanted Mar. '16AdvertiseContactForum Letter 8286
The finishing.com Hotline: Serious Education ... plus the most fun you can have in metal finishing. Ted Mooney, Webmaster
Patio Set (Aluminum vs. Coated Steel)
Hello,
I am getting ready to buy an outdoor patio set. I found two different sets that I like one is aluminum and one is coated steel. I like the steel one the best but I have heard that aluminum won't rust. Will the coated steel rust? What are the differences and which is the better choice?
Thank you for any info you have! Amy Higgs
- Denver, Colorado
Aluminum won't "rust", but it will corrode. Both will corrode over time since they'll be outside. How long depends on numerous factors: the quality of the paint, thickness, quality of the pretreatment, the environment, alloy used, etc.
How long your equipment will last is unknown. It was most likely coated at a job shop. Some job shops conduct outstanding pretreatment and use quality paint. Others, wipe off the dirt and spray on the cheapest paint that will stick.
My personal choice would be aluminum since it will (theoretically) form an oxide layer that helps reduce corrosion. Plus, if it does corrode, it's not as apparent as red rust. I'd also imagine aluminum to be lighter than steel, assuming the same design.
Christian M. Restifo
Circle-Prosco, Inc. - Pittsburgh, Pennsylvania
I live on a salt-water lagoon and can certainly echo what Mr. Restifo says about coating quality being the most important parameter!
We bought some painted steel folding lounge chairs for our patio last year and, without exaggeration, rust was seriously discoloring the paint in two weeks. Unfortunately, we had thrown away all the packing materials and labels by then.
We also bought a steel 'umbrella table' and set of six chairs, and have seen no signs of rust yet even after leaving them out near the salt water all winter.
Think about your car, which is steel, and which can last years outdoors without rust despite every kind of adverse situation from overheating to gravel chips to road salt to sub zero temperatures.
Buy the patio set you like, with confidence that it should give you no trouble regardless of what metal it is made of. But if the finish proves shameful, show them your letter here and tell them to take it back. And if they won't, include all the particulars on your next letter smiley
Teds signature
finishing.com
Pine Beach, New Jersey
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It is not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2016 finishing.com     -    Privacy    -    Search
How Google uses data when you visit this site.
