HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 8205
Surface protection for aluminum from deionized water
I am looking for a surface finish to put on aluminum that will protect it from deionized water.
Joe Solloch- Port Washington, New York
There are a few different ways to protect the aluminum. You could use a chemical conversion such as a gold Iridite, anodize it, anodize with teflon impregnation, anodize then teflon topcoat it , or just teflon it.
Josh SonjuSonju Industrial Inc. - Kalispell, MT, USA
Joe,
Everbrite Protective Coating is an easy to apply, non conductive, clear coating that will protect the aluminum from deionized water as well as U.V., salt air and other damaging elements. It can be sprayed on, dipped or simply wiped on. The dry film is thin and will remain flexible.
Hope this helps,
Teresa Sedmak
Everbrite, Inc. - Reno, NV
