Letter 8095
Bright Chrome dilema
I want to replace a Bright Chrome finish that include cooper as
base bright Nickel and B556 Chromium, because the parts are failing
the ASTM B 368 CASS test before 60 hr. This is happen due to Faraday
Cage or 3/4" rule. Can you recommend a softer metal coverage that
will hold better? The hole 1 1/2 diameter throw rule seems to be in
place too. The x-ray test is showing very thin plating and the
microscopic images shows a lot of cracks on the surface.
Any advice please!?!
George Serb
- Newmarket Ont., Canada
It is true that ions in a plating bath prefer to take the path of
least resistance so that the plating thickness is greater at corners
than in recesses.
But I don't think the term 'Faraday Cage' is applicable to this
phenomenon, and if we use the wrong terminology it may lead us away
from the correct solutions. I've never heard of a '3/4 inch rule',
and your '1-1/2 diameter throw rule' is probably optimistic when it
comes to chrome plating.
I would start with the chrome coverage problem and figure out what
you need to do. A Hull Cell test will reveal whether your plating
solution is deficient or whether you need an auxiliary anode to get
chrome coverage in the recesses. It should not be too hard to gauge
progress because you will be able to see from the yellowish color
where you are failing to get chrome coverage.
Once you have good chrome coverage, if you still are failing the
CASS test, you need to get better nickel thickness distribution.
Again a Hull Cell will warn you if the solution is deficient. If it
isn't, your experience with auxiliary anodes will guide you toward
one way to solve the current distribution problem, and the use of
simple polypropylene shields to block the high current density areas
is another.
Can you expound on these 'lot of cracks'? I don't know quite what
you are talking about there, but if the plating is cracked, it may be
further indication of something amiss with the solutions. Don't
discard the ideal solution, copper-nickel-chrome plating, just
because it has to be done right
finishing.com
Brick, New Jersey
Dear Reader, please --
- Post a
question on a different subject.
- Answer this question (in non-commercial
fashion).
