Weldability of Black Oxided Parts?
Q. We are evaluating black oxide as an intermediate tool for corrosion protection on piece parts for our welded assemblies. Does anyone have any information of the weldability of cold black oxided parts? Our welds must meet AWS D1.1 criterion.
Steve Knapple
- Waverly, Nebraska, USA
A. We have clients that weld without problems the products that we Black Oxide treat for them. The only complaint that we sometimes get is regarding the fumes that the weld produces, since the parts are covered with an water soluble oil.
Hope this helps,
Carlos Cielak
plating shop - Mexico City, DF, Mexico
A. NO PROBLEM WELDING COLD BLACK OXIDE IT ONLY SMELLS LIKE BURNT EGGS.
CHRISTOPHER THOMAS
- W P B, FLORIDA, USA
Q. We recently provided some black oxidized bolts to a customer, they say the look rust red after being welded. Any suggestions on what this red coloring is and what is causing it? The bolts arrive at the customer black oxidized and oiled. Almost immediately after the weld they look like they have rust.
PB
Patti B
automotive fastener distributor - Indianapolis, Indiana
December 3, 2012
A. Hi Patti. Black oxide is simply an ultrathin black rust that relies on a post-dip in wax or oil for its corrosion protective qualities. If you weld it, you burn off the wax or oil and are left with plain steel that will rust. Re-oiling immediately after the welding may help.
December 3, 2012
