finishing.com logo
    HOME / sitemapFAQsBOOKSHelp WantedsAdvertiseContact   you are here: Hotline/Forum => Letter 7439
Key/Keyway Lengths for Different Shaft Materials
I am a college student researching - I was wondering if you could help me with the following questions:
If possible could you direct me to some web sites or other sources from which I can obtain the information?
1)How is a shaft fitted in the bore of a component to avoid eccentricity?
2)What are the effective lengths of key for different materials shaft diameter? 3)Give examples of correct type of key and key materials from standard manufacturers tables.
Craig Adeleted
electronics - Newport,Wales, United Kingdom
ANSWER, or ASK a related Q. POST an unrelated Q.See HOT Topics
disclaim
 seek
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2013 finishing.com     -    Privacy    -    Search
