Hydrogen Project
I need to do a project on hydrogen but I don't know what to do. Help? Age-13
Jeisson Neira
- Hoffman Estates, Illinois
"Earth Science for Every Kid: 101 Easy Experiments That Really Work"
by Janice VanCleave
or eBay or Amazon
Hydrogen is an element. It can combine with different elements to make many different types of chemicals. For example, 2 hydrogen atoms combine with one oxygen atom to form one molecule of water. Hydrogen can also be found as a gas. Two hydrogens bond together to float around in a gas form.
Go to a search engine like www.google.com and do a web search for "hydrogen" and see if you can get some more detailed info. It would be better if you could go to a library and ask a librarian for help. The library will probably give you more of what you are looking for.
tim neveau
Tim Neveau
Rochester Hills, Michigan
