-----Solutions to Problems with drying of green passivation
Hi,
How to dry green passivated zinc plating without water stain and scratches?
Rajesh Kumar- Maraimalainagar
Dear Mr. Rajesh,
Use a "Wolf" blower with a hot air attachment. Only problem, it's not a lifetime investment, and requires repair frequently. Better, to use an"Air Curtain" (used in Shops to keep the dust out) with heater below to supply some warmth. Best, buy a vacuum cleaner and use the reverse flow to blow the air over your components individually.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
