Anodizing of small dia. tubing interiors
I am a professor of analytical chemistry (Chromatography)that needs help finding a solution to anodizing problem. I have some thin walled aluminum tubing that I need hard anodized on the interior (uniform coating). The tubes are 100 mm long with an ID of 0.4 mm. Thank you, DJozan
Dj. Djozan
Djavanshir DJOZAN
University of Tabriz - Faculty of Chemistry, University of Tabriz, Tabriz-IRAN
The diameter of that tubing seems to fight against what you want to do.
If you can get the required 0 degree sulfuric acid to recirculate through this tube rapidly enough to prevent overheating, your next problem will be to run a cathode wire through the tube, sized large enough to carry the current, and preventing the wire from touching the tubing, causing an electrical short circuit.
It's quite a challenge, Mr. Djozan.
