Stripping powder coating from aluminum
I would like to remove powder coatings from mispainted parts and use them again. The base metal is Aluminium and Mild Steel.
Pidi
- Lahore, Pakistan
As yet there would not appear to be a universal stripping medium that works equally well on all types of Powder finish on all substrates.
There are several methods used for stripping aluminium and steel parts. More information is required to determine, both the type of product you wish to remove the coating from,and the type of coating you wish to remove.
Chemical stripping carried out in a Rotary stripping systems is currently being used for the removal of powder coatings from a variety of components,from castings and light weight spinnings for the lighting industry to much larger articles such as 7mtr extruded aluminium sections for the window and door industries.
Peter Gammage
- Wymondham. Norfolk. England
