Blisters and bubbles in zinc and yellow
Why blisters/bubbles are formed in yellow passivated zinc plated surfaces?How the problem can be arrested Clarify..
Ravi janardanan
- Chennai,TamilNadu, India
With out more information it's hard to tell.
Your problem might be delayed blisters, these appear when there is an excess of additives and / or bad preparation (cleaning).
Carlos Cielak
plating shop - Mexico City, DF, Mexico
Its been a few years since I was a plater , but I would suggest wet blast a few parts and try processing , if you get good results , your cleaning cycle is the likely culprit
Ron Landrette
plating equipment supplier - Bristol, Connecticut
