-----Internal hub lubricant
I need to apply a dry or wet lubricant at the clutch disk internal hub, actually I provide the user with a small grease envelope. I do prefer dry.
- I intend to apply it when it is manufactured.
- The lubricant shall be water resistant.
- The internal hub is from 15,8 mm to 25,4 mm nominal diameter
The piece to be treated are about 140000 a year.
Gabriel Calos De Vitservicios tecnicos - Cordoba-Argentina
So manufacturing will proceed:(?)
- manufacture internal hub
- apply dry lubricant
- manufacture clutch disk assembly
- package clutch assembly with grease packet
You are looking for a dry lubricant for you to apply at the factory, to be supplemented with a package of grease for the user to apply during installation of the clutch?
Hi, Gabriel
Millions of automotive components are manganese phosphated for similar purposes, so if you are looking for a process to employ in-house, you might consider it.
November 27, 2011
