Electroless Ni removal
Production Engineer, small aerospace machining company in New Jersey. Removal of Ni plating and its effects on close tolerance parts. Aluminum alloy base metal.
Nick Mag
- Hillsdale, New Jersey
Nick.
Stripping nickel off aluminum is not as much the concern as is the use of the chemicals to strip it off the aluminum.
Most shops will use 50% Bv nitric acid at room temp.
It works on electroplated nickel to high phos nickel; High phos being more corrosion resistant takes longer.
Dimensionally there is little if any material removed.
Nitric is nasty stuff. caution is advised when using this chemical. when you get it on exposed skin, the skin turns yellow. If you plan to do this yourself read the MSDS and follow the guidelines.
One other caution: overloading solution with lots of surface area does cause violent exothermic reactions. You are best advised to let the pros handle this for you.
Todd Huehn
- Blaine, Minnesota
