-----Will Zinc phosphating improve bonding
Dr Rani JosephCOCHIN UNIVERSITY - INDIA
Yes.
A Calcium Modified Zinc Phosphate is the best to use when you want to increase bonding with respect to using an adhesive.
Chris Ellen- Bramalea, ONTARIO, Canada
Depending on what you're bonding you may want to look at an adhesion promoter, zinc phosphating, or a simple cleaning. The term bonding gets used a lot a different ways. More detail is needed before you'll get any information you'll be able to use.
Jeff Watson
- Pearland, Texas
