Need for phosphating before fluidized bedthermoplastics?
Does anyone know if it is necessary to use an iron or zinc phosphate when using thermoplastics in a fluid bed process? I thought that phosphates were used primarily in electrostatic powder spray operations.
Chris
Chris Ballew
- Newport, TN. USA
If you are preheating the metal prior to coating it will be effectively destroyed by the heat. You can use iron phosphate if it is a convenient method of cleaning the parts. Temperatures below 250deg C are just about allowable to zinc phos but there will be some loss of performance. Post cure certainly benefits from proper pretreat giving enhanced performance.
Roger Bridger
Walterisation (UK) Ltd - Croydon, UK
If you are applying an organic coating such as plastisol over steel, then yes, you may use iron phosphate as a pretreatment to facilitate adhesion. I have direct experience with just such an application with a fluidized bed.
Ron Woods
Benchmark Products Inc. - Indianapolis, Indiana
