-----Need pickling tanks for galvanizing plant
April 9, 2012
RFQ. Dear Sir,
We are one of the biggest steel tube manufacturers and are looking for Pickling Tanks for our Galvanizing plant as per details given below. Hence I would request to suggest a good supplier from Europe especially from Germany
1. Pickling Tanks Polypropylene -- 2 NOS
(PP Tank with guide acid proof structure Size- 8000 X 1300 X 2000
PP Plate Thickness- 40 mm and
Structure - I beams 125 mm x 5 mm and to be GRP Coated
Drain Valve Size 80 DN 16 PN from Bottom plate).
2. Pickling Tanks Sprayed -- 4 Nos
(PP sprayed Heavy duty.
Size width- 1280 mm, height- 680 / 780 conical shape
Length- 1200. PP plate Thickness 100 mm.
both plate joint with acid proof PP coated rod.
steel company - Sohar, Oman
