finishing.com logo
    HOME / sitemapFAQsBOOKSHelp WantedsAdvertiseContact   you are here: Hotline/Forum => Letter 58310
Need plating shop for electroforming phonograph record stampers
February 22, 2012
RFQ. Hello:
We are a vinyl record pressing plant in Cleveland, and due to ever increasing demand for vinyl records, we are interested in finding additional plating shops interested in making the metal stampers we use to manufacture records.
While still a niche industry, demand for vinyl records continues to increase substantially. There is currently one independent plating facility in the U.S. which services this industry, and while it is extremely reputable and does excellent work, we are interested in speaking with other facilities due to the increase in demand.
Thank you!
Matt Earley
- Cleveland, Ohio, USA
contact
March 7, 2012
"we are interested in finding additional plating shops interested in making the metal stampers we use to manufacture records"
I am unfamiliar with the process of manufacturing records, I am wondering if you are looking for a plater or a stamper? Could you clarify what you're looking for? Thanks!
Sara Mortensen
Bales Mold Service - Downers Grove, Illinois, USA
March 7, 2012
Hi, Sara.
Briefly, a lacquer master is engraved, metallized with a spray silver solution, and then nickel plated very thickly, and separated from the lacquer master. This nickel electroform can be chrome flashed for abrasion resistance and used as a "stamper" (actually a mold might be a better name) for the vinyl records. More commonly, and if high volumes are involved, additional nickel electroforms can be made by electroforming onto the first nickel electroform and separating them, and electroforming more "stampers" from the 2nd generation electroform.
Because of the precision that is required, it is rather a specialty. Equipment whereby the discs are mounted onto a spindle and revolve during plating, and include specialty shields, is usually employed. The plating solution is usually sulphamate nickel, and often the plating cells include specialty anode arrangements to deliberately generate sulphamate breakdown products sometimes simply called "magic stress reducer".
finishing.com
Brick, New Jersey
rfq
ANSWER, or ASK a related Q. POST an unrelated Q.See HOT Topics
disclaim
 seek
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2013 finishing.com     -    Privacy    -    Search
