Need Silicon Carbide for Composite Nickel Plating
RFQ. I need to know in your Electroplating Nickel tank where you build up cylinders and you use Silicon Carbide in the Nickel where can I find a Company who will supply the right silicon carbide to me and the grams per litre? Also the right grade must be supplied.
Abraham
Abraham Beneke
Sales - South Africa
January 19, 2012
