-----Tin Plating Anode Problems
Current questions and answers:
Q. We've been working on SnSO4 bright acid tin plating onto copper. The condition we are using is 30 A for 30 min with current density of 11 A/sq ft. It is plated onto a long copper foil that is winded on a mandrel connected to the cathode. The anodes are several pieces of tin sheets in polypropylene bags. The anodes are connected and total anode area to cathode area is ~1:1. We have seen tin anodes darkening normally after each plating and the plated surface is shinny. Our question is that after each run, scrubbing the surface of anodes and washing anode bags ⇦ huh? takes 1-2 hours which is much longer than plating itself and that's limiting our ability for production. Would there be any potential problem in our setting?
Yangwei Liu- Houston Texas
February 9, 2021
A. It sounds to me like your anodes are going passive. I would try doubling your anode surface area and see if that eliminates the issue.
David De Pena- GRAND JUNCTION, Colorado
February 25, 2021
Acid Tin Plating Current Drop problem
Q. We are doing Bright tin plating in Acid Tin Bath. we are facing problem of gradual Current Drop in the set current.
Initially f we set the Current of 270-300 Amps. after some time it reduces gradually and comes to 130-160 amps. But Voltage is Same no change in the applied voltage.
We are loading 300 Dm2 material Area in the Barrels.
We check the Rectifier and also replace it but problem continues.
- Bhilad, Gujarat, India
July 15, 2021
Q. We are doing electro-tin plating on copper wires. Lately we observed that the percentage of tin is depleting from the bath and the acid percentage was going up. With this we also observed that the tin anodes have black/grey film on them. could this be causing the high acid and low tin content, if so please advice why do the anodes have film on them and how to solve this problem.
Asit Kumar- New Delhi, India
A. Sounds like your anodes have gone passive and you are plating out of solution. Applied voltage is probably higher and possibly you see more gassing from the parts. Cause, normally less than a 1:1 anode : cathode ratio. Scrub clean, and add more anode area.
James Watts- Navarre, Florida
Q. Dear James, Thanks for getting back to my problem. I have checked the ratio and found that the anode area is twice the dipped wire in the tank. The problem is that when we start with new/clean anodes ,initially the voltage is about 2 volts and current about 90 amps but after sometime we observe the current going down and to maintain the current at 90 amps the voltage of the bath increases to about 4.15 volts. We are operating at about 250 amps/sf.ft current density. Also the acid content of the solution keeps rising.
ASIT KUMAR [returning]- new Delhi, India
? What are your bath parameters? All components and temperature. How close do you keep them? What is your analysis schedule?
Q. Thanks for responding back.
The bath composition we are using is
Tin as metal 55 grms/litre
sulfuric acid 50 grms/litre,
the temp. of the main tank is room temp. about 32 deg c
there are 30 turns of wire in the tank
the wire dia is .350 mm
the dipped length of each turn is 3 ft 10 inches
the total area of wire dipped in the tank is .4146 sq ft.
taking a current density of 250 amps/sqft we arrived at a current of
90 amps.
the speed of the wire is 75 mts/min
we add about 2 gm/litre gelatin to the tank .
What we observe is that the anodes are not consumed to a great extent. we analyse the solution on a daily basis and we notice that the tin content keeps going down and the sulfuric acid keeps increasing. the anodes also turn black.
To give you an idea of the solution the tin is in the range of 35 grms/ltr and the sulfuric acid has shot up to 102 grms/ltr. please suggest where is the problem. should we throw this solution and prepare a new solution ,if so please advise the tin and sulfuric acid concentration.
- New Delhi, India
A. (REF: books)
1- You may have lead contamination in your anodes.
2- Shouldn't the color of the anodes be yellowish if so, your anodes should be in over passivation state.to do so you need to insert anode slowly into, power on max with a dummy, so to over passivate the anode; to hold this state of over passivation your anode should be a lot smaller than your cathode.
Hope this help, and feedback would be great.
Khair Shishani
SORRY, the second part of previous answer is not applicable for the mentioned tin plating solution .
Khair Shishani
Anodes not dissolving in bright acid tin plating bath
Q. We use acid bright tin plating bath. Conc-30 g/lit and sulfuric acid 120 ml/lit max. We normally use 4 anodes of size 300 x 100 x 12.5 mm. We usually get a bright good finish at 40 amp. But presently we plate at 30 to 35 amp and also we have been advised to reduce the anode surface to a min. 2 anodes. For the past 2 weeks we observe that the anode is not dissolving and the solution gets depleted of metal content which forces us to run plating by the addition of stannous sulfate. During the past years, since anode dissolution was more, the metal content normally shoots up and we used to dilute the bath.
Also when the anode dissolves, we have seen black coating on the anode surface which when cleaned, the bright crystalline surface will be exposed. Now we have no such film, but a dull grey coating with foaming from the anode surface even at a current of 20 amp. Since the plating is mainly from the bath, the finish is also not good. We use lesser brightening agent since it produces micro bubbles on the tiny object we plate. The bath consumes more additive. Since the anode is not dissolving, we have checked our electrical lines, activated the surface of anode and also tried with increasing and decreasing the cathode current density. What would be the factor affecting the dissolution of anode suddenly? Is it due to contamination of the bath or anode? Analytical reports of the solution shows the metal content and sulfuric acid content are within the specified range.
Process Control - Chennai, Tamilnadu, India
December 21, 2010
When is the last time that you changed the anode bags and possibly reactivated the anode? James Watts- Navarre, Florida A. Hi Chithra, ![]() David Shiu - Singapore |
A. Hi ,
Some dilution of solution will help and remove anodes when you don't plate.
Praveen Kumar
plating process supplier
Mumbai, India
Cleaning Polarized Tin Anodes
We are currently working to resolve an issue we seem to be having with our tin line and I'm inquiring as to whether there is a way to clean tin bars which have been polarized. We are attempting to create a fresh plating bath however we've replaced all of the tin bars, which should still have much life to them but currently cannot be used since the are black and polarized. Since the replacement of the bars was an expensive one, we would prefer to be able to salvage what we currently have.
We have already tried getting the bath temp to where it should be (around 100 °F) and having it circulate. The idea was that this should work however it seems that this hasn't been as beneficial to the cleaning of the anodes as we had hoped.
I appreciate any advice or help!
- Ohio
April 21, 2016
A. Hi Nicole. Two pages from "Garden State Branch AESF Electroplating Course Manual" --
Copyright note: We try to be careful and supportive of copyright, but ... Because this volume was offered for decades at cost of printing, and the other ways of getting it out to people have dwindled to non-existent, and because the whole book was typed by my administrative assistant at no cost to anyone but me, and I hate to see those long months of work lost to posterity and completely wasted, I don't feel bad posting such excerpts. Credit to F.A. Lowenheim for the original article, and to F.J. "Cy" LaManna, editor of the 1986 edition 🙂
April 2016
Q. Thank you for your response!
In an effort to solve our polarization issue, we are also looking having testing done for contamination of iron. From a previous question, I'm wondering if we should also have the bath solution tested for lead?
We haven't been as attentive as we should be to the testing of the plating bath. We currently test stannous tin, free acid, and have an outside lab test those in addition to some additives (MSA and a Primary). The in house testing is done on a non-regulated basis from what I have found (definitely not daily) and the outside testing is done monthly unless there's been an issue. We also only perform hull cell testing when there's been an issue. From reading the information on those pages, I noticed the need to determine the amount of free alkali daily as well?
It's obvious I need to have a better testing plan implemented regardless.
- Youngstown, Ohio, USA
April 21, 2016
Tin Anodes Turn Black After 2 days
Q. Our company encountered faster oxidation rate of Tin anode and Tin anode turn black color 2 days in the bath.
Wayne Lim- Thailand
August 25, 2017
? Hi Wayne. We added your inquiry to a previous thread on the same subject. Please tell us what kind of plating you are doing, i.e., bright acid tin (stannous sulfate?) or MSA-based, or alkaline stannate bath.
August 2017
Q. Hi Ted. We are using bright acid Tin.
The black sludge from the anode balls makes the anode bag choke. It is blocking the current and giving high voltage, making defects in the products.
- Bangkok, Thailand
August 25, 2017
A. Hello, The first thing I would do is give the bath a complete analysis. Be sure it is also analyzed for Stannic Tin. Too high a concentration will definitely cause you problems. Secondly, verify you are using pure tin anodes, and check the anode bars and baskets to ensure the proper current is being distributed. A clamp ampmeter is the best to use. For a bright tin sulphate bath, these are the recommended steps I would take.
Mark Bakerprocess engineering - Phoenix, Arizona USA
August 30, 2017
Tin Anode in Hull Cell Turned Brown
Q. My situation:I recently conducted some Hull cell test on an acid tin solution at 2 amps for 10 minutes and noticed the anode turned brown. Does anyone know why this is?
Mark AllabushTechnical - Basingstoke, England
June 29, 2018
