Contamination of steel shot from titanium [Italy]September 29, 2009 To all, GIGOTTI MAURICE
October 2, 2009 There is always the possibility of cross contamination no matter what steps are taken. If you have enough volume, it is highly suggested to get 2 different machines dedicated specifically to each separate process. This is normal in the aircraft industry.
October 7, 2009 From a corrosion standpoint at least, I wouldn't worry too much about titanium particles embedded in steel. However steel particles embedded in titanium is a big problem. Prevention, i.e. using dedicated non-ferrous shot media for anything that isn't carbon steel, tends to be a much better option than decontaminating the parts after you have blasted steel into the surface.
October 11, 2009 The maximum volume rate will be: 24 titanium items and 8 300M
items per month. It doesn' t seem to be very high. Mr Gigotti
Save
This Page (why?) - Home - ©1995-2009 finishing.com
