HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 50074
Need plating of 1018 Shaft to pass 500 hrs of humidity test
September 23, 2008
I have a 1018 shaft that must pass a 500 hr humidity test. Right now it calls for a high phosphorous .0003" min electroless nickel plate. I'm looking for a lower cost solution that will comply with the 500 hr humidity test. We are also looking for a new supplier to do the electroless plating or suggested substitute.
Kelly Strzokparts producer - Aurora, IN, USA
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
