50001
Need lacquers and lacquer coating machine
for buttons and buckles
September 17, 2008
We have an electroplating plant in which we plate fashion good
accessories like buttons, buckles, washers, eyelets, zipper pulls.
etc. The size of material to be plated varies from (diameter 1 mm to
10 cm). Our major problem is choice of a correct lacquer and lacquer
machine which can apply the lacquer on the objects smoothly and give
a pleasent and shiny look.
Our finishes are
antique copper, antique brass, tin, white bronze, antique silver,
black nickel free
Can any body select one or more suitable lacquers and methods of
application (my major problem is antique silver which becomes yellow
even after applying lacquer on it)
Azhar Ali Mahar
Karachi
Azhar Ali Mahar, process Engg
employee - Pakistan
