letter 5095
Coating Copper Cookware Interior
I have copper cookware with an interior coating to prevent copper from leaching into the food. The coating has worn away after years of use. I want to reapply a proper coating but do not know what the material is and where or how to get it done.
Lee Benuska
- San Marino, California, USA
I have used copper cookwear having a thin tin coating on the food side. This was probably applied by either electroplating, or by hot application using a plasma spray, or actually applying molten tin to a flux cleaned copper surface (like soldering). The tin adheres well, and is non-toxic (although copper has been shown to be more beneficial then harmful to humans).
W. Carl Erickson
- Rome, NY
A William and Senomia retail location should be able to supply you with a name of a company who will eclectroplate your copper cookwear and return it in "like new" condition. I had the same problem and they had the answer.
R Dahl
- Faribaule, mn
I want some patent about primery data of column and agitation leaching of copper.
qwe.pdf
Tehran University - Tehran, Tehran, Iran
Dear Reader, please --
Post a question on a different subject.
List of Directories
