Letter 5056 Nonwet/ dewet. I am having problem with solderability, non wet and dewet. The lead frame material was alloy 42. I am new in this process and trying to figure out what is the cause of dewet or nonwet. Below are the process :- - lead frame was subject to high temp 435 deg C - pre-clean and 100% tin plated ( rack) - subject to oven burn-in at 150 deg for 84 hours. - hot solder dip - this is where I have problem. * Need advise on what is the possible root cause. * What do I need to look for ? * What sort of test that I need to do ?.<?P> Koh Heng Lim
Dear Reader: please choose what you want to do.
Save
