49544
Corrosion of stainless steel with diluted
sulphuric acid [Egypt]
August 1, 2008
I am working in ammonium sulphate , we are feeding ammonia with
sulphuric acid in a reactor then making evaporation for solution to
produce the salt , produced vapor condensed in a shell and tube heat
exchanger by action of cold water, by time noticed fouling of the
heat exchanger by forming calcium carbonate as scales which decrease
heat transfer, we started to add sulphuric acid to cold water to
react with scales and try to keep ph from 7.4 to 8.2 but at some time
may ph decrease to 6 or 6.5
we noticed apperance of leakage in tubes of condenser
my question is , is the diluted sulphuric acid with water which keep
ph 6 or 6.5 can corrode stainless steel 316 l or there are any thing
else
Ahmd Nadr
process engineer - Egypt, Suez
