![]() (Cycles thru suppliers) |
Bead Blasting vs Citric Acid Passivation [Massachusetts]July 29, 2008 Which process would be better for surgical instruments - bead blasting or citric acid passivation. We are under the impression that bead blasting is harmful to the instrument and that treating it with citric acid is better to remove the staining and to reapply the passivation. We believe that bead blasting only opens up the instruments pores to more staining or rusting. Does anybody have any information to verify or nullify this idea? Bruce Cunningham
August 26, 2008 Bruce,
Save
