Platinum plating for high voltage (~1000V) electrophoresis
May 27, 2008
Hello,
I'm a research engineer in a biophyics lab and I'm interested in plating small (1cm^2) electrodes with platinum for a high voltage electrophoresis application - separation of DNA in a conductive gel matrix (such as agarose or polyacrylamide with Tris Borate EDTA buffer) for biotechnology applications. From past experiments with solid Pt electrodes I expect the required current densities during operation of the plated electrodes to be on the order of 50mA/cm^2. I would like to achieve a coating that is as durable as possible, as the electrodes will need to be cleaned regularly. I am also interested in plating Pt-black, as the higher surface area might offer advantages, though this is not a critical requirement.
I've spent the past month experimenting with hexachloroplatinic acid and tetraammine (5Q) plating baths to plate platinum onto stainless steel (hexachloroplatinic acid) and copper (5Q bath). I've had the best success with the 5Q tetraamine bath, which I have prepared according to a paper published by W. J. Basirun (Studies of platinum electroplating baths Part IV: Deposits on copper from Q bath. W.J. Basirun et. al. J. Appl. Electrochemistry, 26 (1996) 873-880): 26mM Pt(NH3)HPO4 + ~30mM sodium phosphate buffer, buffered with NaOH to pH10.4 at 95C. My bath is 40mL of this solution in a 60mL glass beaker [beakers on
Amazon] sitting on top of a stirring hot plate, with stirring effected by a teflon-encased magnetic stir bar and the temperature is kept between 92 - 96C (approximately).
My electrodes are paddle-shaped pieces of copper (99.6%) waterjet cut from 0.015" thick shimstock and are approximately 0.5cm x 1.5cm. I prepare the surface by sanding with 1200 grit emery paper, washing with ethanol, and then electropolishing in phosphoric acid (522g/L) at ~2V for 10 minutes (current density ~40mA/cm^2) until the surface is shiny. I then rinse in deionized water, dry with N2 and immerse in the plating bath.
I use a piece of platinum wire as a counter electrode, bent in a saw-tooth shaped ring surrounding the copper working electrode at a distance of ~2cm. I do not have a reference electrode and merely apply a potential from an adjustable supply across the two electrodes, and monitor the voltage and current with multimeters. I have used this configuration to deposit both shiny (1.9 - 2.4V) and black (2.3 - 2.5V) platinum with good success - the adhesion is very good and the plate is difficult to remove. However, when I run the electrodes in a strong salt solution at ~40mA/cm^2 (2.5X TBE to achieve high currents at ~30V, for testing) I notice that there are small blue nodules left on the surface of the plated electrode. These deposits are the colour of copper sufate and I am certain that they are ionized copper from the underlying metal. If I can stop these deposits from appearing, I think I will have accomplished what I need to for this proof-of-concept design.
I have a number of questions that I have not been able to answer by looking through literature. I have little knowledge of chemistry, electrochemistry in particular, but I have found your site quite useful thus far and I would like to thank you in advance for any assistance.
In no particular order...
1. What is the 'efficiency' of a bath, in terms of the amount of Pt that can be plated out of it, compared to the amount of Pt it contains, if such a number exists? Is there a surefire way to tell that you've depleted your solution?
2. Is there something inherently uncontrollable about using a two electrode system? If so I'd appreciate any advice on setting up a three electrode system.
3. Are there tricks to ensuring that the plated Pt will have no cracks through to the base metal, if I am not worried about the appearance of the finish? Do alternate layers of Pt black / shiny Pt help?
4. Does operating the plated electrode at high voltages and currents cause damage to the plating? (We currently use solid Pt wire electrodes [the standard for such instruments] and have not had problems with electrode breakdown.)
5. Is there a better choice for base metals, given that my constraints are fairly loose (good conductor, preferably resistant to corrosion as part of it will likely be unplated)?
6. For my application (high voltage, high current densities, in salty buffers), is there a metal other than Pt that might work? (We haven't spent much time experimenting in this regard, but found Pt to be the only metal to work).
7. Is there a way to replenish the Pt in the baths to get around possible problems of bath efficiency?
8. I always encounter references to Pt gauze for a counter electrode; should I be going in this direction as well?
9. Is degassing/deoxygenating important, as I have seen references to it?
This project is currently in a prototype phase, but this is the last major problem to be worked out prior to production. I am keen to speak with companies that specialize in this sort of process, and I contacted four of them previously, but have not received any responses.
Scientific Engineer - Vancouver, British Columbia, Canada
June 3, 2008
Dylan
Thanks for a clearly worded and detailed question. It is a rarity.
I do not believe that you will easily get acceptable results by following published papers.
There are many potential problems with your method. As examples; no plater would for choice, use abrasive paper, degrease with ethanol (a poor grease solvent) dry before plating etc. In addition, plating onto stainless steel introduces many other problems and requires special processing to get adhesion. Forget reference electrodes. Platers operate at a predetermined current density, we are usually only interested in voltage for anodising processes.
The plating industry has spent many man/years on developing processes which work reliably. I believe that you could find better use for your research time than trying to emulate them.
Which leaves you with the next problem, finding a suitable supplier.
On the 'home' page go to 'chemicals' then 'Search engine' and enter
'Platinum'.
Your electrodes are so small that any of the precious metal supply houses could probably be persuaded to make a couple of samples for a good cause.
If you are still interested in the technology try
"Modern Electroplating" Lowenheim, John Wiley & Sons inc.
[adv: this book on
AbeBooks,
eBay,
Amazon]
Hello,
You have a very complicated system.
We do Pt plating (0.0007" thick) first and then it is diffused.
- Minneapolis, Minnesota
Hi,
We platinum plating up 20 micron thick on titanium, tantalum, niobium, steel, coppper.
- Chennai, Tamilnadu, India
August 9, 2008
