Cycles thru suppliers.
Electrocoagulation for wastewater treatment?
Letter 4924  .
I was wondering if anyone else has heard of or had experience with electrocoagulation equipment for waste treatment. I have seen some companies advertise a system in which wastewater flows through tubes and the electrical current drops out solid material. This is supposed to eliminate the need for floc chemicals. Our application is for a nickel plating line. Thanks! Chris
Chris Ballew
- Knoxville, TN. USA
Ed. note: We now have an Electrocoagulation entry in our FAQs
Hey Chris,
You have no idea what you asking for ... Vendors can be very protective of their products. And even the best products can be misused or mistested.
No one wants to up-grade the waste treatment area more than the EPA. Soooo, they tested two of these units. As I remember, the results were mixed in the units ability to lower the ppm's metals going thru the system. Every shop/waste stream is a little different so you may want to test it out for yourself.
The EPA report was on-line somewhere in the EPA site, check it out.
Fred Mueller, CEF
- Royersford, PA
You'll also see that many of the companies that offer ECoag are like the changing of the seasons - one day there here, one day they're not.
Do you have any specific goals that you are trying to achieve or are you just hunting around? There are several other options to eliminating chemical usage in WWT, as well as simply not creating wastes at all. We offer a recycling system service through a major chemical producer that will pay you for recovered nickel on a lease basis. Depending on system size, lease rates (monthly) can be as low as $4K for a long term contract (5-7 years).
ROI's are generally in the range of 9-12 months, and then it's pure profit from then. All metals are recycled back into plating grade raw materials, so it achieves the intent of the EPA recycling program.
Tom Baker
      wastewater treatment specialist
Warminster, Pennsylvania
You might look here: http://www.epa.gov/swertio1/products/newsltrs/ttrend/ttecoagn.htm
James Totter, CEF
- Tallahassee, Florida
Ed. note: The indicated link does not work anymore. This is typical of the Internet, I suppose. If there is any hard copy, a reference to that would be great. Thanks.
As president of a supplier in this field, I have been actively involved in using electrocoagulation specifically in the coal mining field in dealing with de-watering coal fines and wash plants where we have reduced the need for chemical flocculation. We have also been asked by the Dept. of Environmental Services in Pa. to do testing on acid mine drainage waters and have been successful in increasing the PH and dropping out the solids. We have actually achieved a 99.97% rate of treatment for TSS's.
James B. Long
- Ebensburg, Pa.
We recently used a "field test" EC unit on water with suspended particulates. Various metals, such as lead, were associated with these particulates. I watched the unit give a quick and complete separation of solids and water. The results was water containing 3 ppm lead being reduced to water containing < 0.05 ppm lead. They tell me that lead is one of the harder metals to remove.
Paul Dial
- Springfield, Missouri, USA
Dear Sirs
I'm a student in an engineer school in Lille (France).
I'm looking for information about electroflocculation (electrocoagulation) used in waste water treatment: "my" waste waters contain some latex particles and I'd like to know if electroflocculation has already been used on that purpose.
Can you please send me schemes, photos, explanations or/and bibliography about that?
thanks in advance
Best regards
David Schockaert
- Lille, France
David, I've heard that the more people who will see something that requires somebody to volunteer, the lower the odds that any one will, so I think the odds are very low that a stranger is going to do a free literature search for you, prepare electronic pictures, etc. I suggest you contact one individual from a few manufacturers or distributors of electrocoagulation equipment, and ask them to send you literature and case studies. Good luck.
finishing.com
Brick, New Jersey
DEAR SIR:
I HAVE BEEN USING ELECTROCOAGULATION FOR THE TREATMENT OF TURBID WATER FOR DRINKING PURPOSE SINCE A LONG TIME . THE FIRST PLANT OF 1350 LPH CAPACITY HAD BEEN GIVEN TRIAL RUN FOR MORE THAN THREE MONTHS IN FIELD CONDITION IN THE YEAR 1985. SINCE THEN A FEW TRIAL RUNS ON DIFFERENT QUALITY OF WATER LIKE WATER CONTAINING IRON IN DIFFERENT FIELD CONDITIONS HAD BEEN CARRIED OUT WITH FULL SUCCESS.
VERY RECENTLY A COMPANY DEVOTED TO ENVIRONMENT PROTECTION IN CALCUTTA , INDIA , SUPPLIED SUCH PLANT TO AN OIL COMPANY FOR WATER TREATMENT. ANOTHER PLANT HAS BEEN UTILIZED FOR REMOVAL OF FLUORIDE IN WATER . WE ARE SURE THIS IS A PRACTICAL METHOD OF TREATMENT OF WATER .
THANKS,
AMALENDU BIKASH PAUL
- SILCHAR, ASSAM, INDIA
apply for free subscription to Water & Wastewater International . . .
EF is very easy to implement. Get yourself a variable power supply (2-10 volts and 1-2 amps), a few pieces of aluminium sheet, a plastic tank, some dirty water and try it for yourself. You will be surprised how clean the water becomes after a few minutes. Now the difficult bit.... Extrapolate your pilot plant (!) to an industrial scale and off you go.. The most expensive part of the system is the power supply but the rest you can build without difficulty.
Colin Tallis
- Leeds UK
I work in wastewater treatment and have never considered electrocoagulation before. As a general rule:
* how much power needs to be added to separate the solids? $/£ per m3/water?
* what current & voltage is applied?
* Is it added to standard clarifiers?
Russell Reed
- Reading
Electrocoagulation is a cost effective alternative to chemical treatment and more. Costs can be as low as £1.00 GBP per m3. It can remove contaminants which are very difficult to remove with chemical treatments.
A great deal depends on the water/effluent being treated and the design of the electrolysis cell, including voltage amps and cost.
Neil Stewart
- Perth, UK
Chris,
We just completed a study at George Washington University on the use of EC for metals removal. Nickel at 126 ppm was reduced by more than 99% at pH of 10.
David Rigby
wastewater treatment engineering - Arlington, VA
A variation of the electrocoagulation process is one in which the gas generated by the process captures the coagulated pollutants and floats them to the surface. Known as electroflocculation, it offers the possibility of a one step process, in which polluted water is pumped into a processing reactor, the pollutants are floated to the surface and the cleaned water is pumped out at the end of the process. Theoretically there are no chemicals to be added and no filters which need cleaning.
David Leviston
- Merimbula, NSW, Australia
Question from Russell in Reading
The energy costs costs for EC can vary according to the waste stream. However, on average you would be looking at 3-7 watts per 1000 gallons. The systems I work with can be bolted on to an existing clarifier, or there is available a vacuum clarifier that removes all the air from the cake and eliminates filter press or similar equipment. The systems can handle up 30 gall per minute.
Ray Long
- London
Could this process effectively to remove the Ni concentration to less than 1 ppm?
Yee Hwang Chong
Water treatment - Malaysia
Gentlemen,
That was interesting to note the interest on Electro coagulation and its benefits.
We have done trials for more than a decade and have found real gratifying findings on these systems.
We have tested on effluents ranging from electroplating,toxic, leather, textile effluents to rainwater/storm water reclamation with phenomenal results at affordable operating costs.
yes it can quite meet the EPA norms however individual users will have to test run the units for their effluents and fine tune the operating parameters to suit their needs as these systems are very difficult to be made to fixed standards in terms of their output.
Please consider a fact that the conventional systems create a new problem in the name of solving one. I mean you land up with huge loads of solid waste in course of treating liquid waste.
Jeyananth .T
- Chennai, TN, INDIA
Electrocoagulation Power Usage? Flowrate = 500gpm. what sort of energy requirements does an Electrocoagulation system have? anything helps.
Danny Medina
Process Engineer - Denver, CO, USA
I am an EE for a company that manufactures EC systems. At 500 gpm, the power requirements are somewhere around 130 Amps at 480VAC.
Eric Lindgren
- Everett, WA USA
Will this process be effective in taking tar out off water that comes from a gasification process? Is it possible to tkae out the solids from milk with EC?
David McElrea
product designer - Tyrone, Ireland
June 7, 2008
To treat Ni with Electrochemical sytems it depends on in what kind of surrroundings the Ni is available.
We tested in 2007 Chemical Ni waste water: we got not below 0,5 mg/ltr. Chemical Ni based on Ammonia. Later we did the same Chemical Ni, but then with K2CO3 and the results where fantastic.
Effluent values below 0,1 mg/ltr. For this wastewater we sold an installation for not only Ni but also Cr6+. Cr3+ and Al, Cu and S2. A Contineous treatment 24 h/d 7 d/w. Capacity 40 m3/day and/but concentrated streams.
So if the Ni is a Watts bath without complexing agents it will give very good effluent value.
Bert R Snijder
- Zwolle, The Netherlands
July 31, 2008
I started using Electro-Coagulation in our mining operations in 2000. Since then I have published a paper on the different types and uses and efficiencies of EC. you may go to the GREEN PAGES which is www.ECO-WEB.com and click on editorials, this will take you to another page where you can click on Authors and my EC paper is either the 3rd or 4th. You can also simply google me under my name and this will give you a lot of information on my use of EC around the World.
Dr Abe Beagles
- Newcastle, Ca. USA
August 29, 2008
Good afternoon,
I am a consultant and at this moment I'm working on designing a water treatment system for a water effluent from a rinse metal process. water pollutants are: chromium, nickel, copper, zinc and surfactants. The idea is to treat the water and return it to reuse in the process. Usually I used the conventional method: chromium reduction and precipitaciòn of this with the other metals. I want to know whether the electrocoagulaciòn would be enough to ensure that water quality? surfactants could be removed wih this method?
Thank you very much for your answer.
Liliana Paola Guzmán
Product designer - Bogotá-Cundinamarca
September 20, 2008
I am doing research in alternate energy resources. DURING ELECTROLYSIS OF CLEAN FILTERED DRINKING WATER USING S.S ELECTRODES,FOR THE PRODUCTION OF HYDROGEN, THE WATER BECAME DARK GREEN COLORED AND TURBID. I WAS USING 30 VOLTS AT 250 MILI AMPS. AFTER 30 MINUTES, THE DISCOLORING STARTED. THE TDS ALSO IS LOWERED. CAN YOU EXPLAIN WHY THE WATER GETS COLORED.
MEENAKSHI SUNDARAM
NEW PRODUCT DEVELOPMENT - PONDICHERRY, INDIA
September 17, 2008
1)What will be the power consumption for EC unit having product capacity of 2000m3/day with continuous flow of 100m3/hr?
The electrodes used are Al and Fe.
2)EC unit is able to remove soluble COD?
Vishal
Vishal Dave
student - India
August 26, 2009
Removal of cadmium,TKN,Phenol,Colour,chromium(+2),cynide etc.. can be possible by Electro cogulation?
Ahmad Khan
Student - India
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
Link to Del.icio.us button Save This Page (why?)    -    Home    -    privacy policy    -    ©1995-2010 finishing.com
