     No Pop-ups! No Spam!
no_pop_no_spam
HomeFAQsBooksHelpWantedsForum  ltr 4917
Serious Education ... plus the most fun you can have in metal finishing.
Sherardising: What is it
(2000)
Q. We are trying to obtain some business that is currently being manufactured in England. One of the processes that are used is "Sherardising". We have very little knowledge about the process and why it is used. Can anyone steer us in the right direction?
And is there a substitute process available in the USA?
Phillip Roberts
- Grandview, Missouri
A. Hi Phillip. March 2004 edition of Metal Finishing Magazine contains an article by Dr. Benu Chatterjee on sherardizing, page 40. There are a number of used and inexpensive books about Sherardizing available at this link at Amazon.
Teds signature
finishing.com
Pine Beach, New Jersey
(2000)
A. Keystone Steel & Wire in Peoria IL does some Sherardizing. The process consists of tumbling small parts with sand, flux, and zinc dust and heating it until the zinc fuses to the surface of the part, followed by a quench.
tom_rochester
Tom Rochester
Jackson, Michigan, USA
(2006)
A. Sherardizing is a method of batch galvanizing. It is ideal for small parts and parts that require coating of inner surfaces, although, there are systems that can do pipes as long as 12', and rail guards. The original system was quite complicated and expensive; however, today there are new systems in use which are simple, cost effective, and environmentally friendly. As far as corrosion protection, I don't know about the old systems, but the one I am familiar with is showing far superior results then any other systems I'm familiar with. Another advantage of this system is that it allows easy application of top-coats and paints.
For more information on sherardizing you can check BS EN 13811 [link by ed. to spec at TechStreet]::2003 (this is the British/European Union standard).
Dorian Shifman
- Charlotte, North Carolina
To minimize searching and thrashing, and to provide multiple points of view, Finishing.com combined formerly separate threads into the single dialog you are now viewing. Please forgive any resultant repetition.
(2000)
Q. I am looking for some technical information about sherardising. What is sherardising all about and how does the application work?
Could one say that a zinc galvanised steel products (anchor, plugs) with additional sherardising process is as good or even better than hot dip galvanised steel products?
Werner B [last name deleted for privacy by Editor]
Q. Please provide the details regarding " SHERARDISING PROCESS ON FASETENERS & MS PLATES"
Ajay Chaudhary
- nasiik,maharashtra, Maharashtra, India
similarly
similarly
(2000)
Hello, Werner. Hello Ajay. We edited your inquiries to reflect the correct spelling of "SHERARDizing"; slight misspellings of this word have given others, and possibly you two, some difficulty finding info about it. This process has been the subject of several threads here. Good luck.
(2007)
It's spelt sherardising with an S. Not a Z.
Andy Cain
- ENGLAND, United Kingdom
(2007)
thumbsup2Maybe it's spelT with an S if you are British, but it spelLED with a Z if you're American, Andy :-).
Fortunately, the process is named after SHERARD Cowper-Coles so, the first 7 letters are sherard either way. Thanks.
Teds signature
finishing.com
(2006) -- this entry appended to this thread by editor in lieu of spawning a duplicative thread
Q. Many times had came came across this new surface treatment process known as Sherardized Coating. Some have even told me that this is a new technology and the SST hrs is comparable with that of Dacromet. I want to know more about this Sherardized Coating.
Daniel Tan
- China
(2006)
Q. Dear sir,
I would like to know about sherardising as a heat treatment method. Thank you for information. Bye.
Atwine Andrew Besigye
Kyambogo University - Kampala, Uganda
Zinc dust to metal parameters for sherardising
(2001)
Q. Hello
I would like to know the proportion of zinc dust/metal in the sherardising. We designed a line of sherardising but we found anything on the subject. For example, we find that for 400 kg of metal, we would need only 12 kg of zinc. But the theory and the practice are quite different...
Thank
Yohan T [last name deleted for privacy by Editor]
- Quebec, Canada
(2006)
A. The simple answer to your question is that it depends. The zinc requirement depends on the surface area of the product you coat. The smaller the coated item is the more zinc you'll require. The larger it is the less zinc you'll require.
To be more specific, I'm familiar with a new Sherardizing system, and they use about 2%-9% zinc proportional to the weight of the coated items, i.e. if you coat small parts then you'll use 36 kg zinc for 400 kg steel, however, if you do larger parts you'll use 8kg zinc for 400 kg steel.
Dorian Shifman
Cost of Sherardizing?
December 11, 2009
Q. Can anyone provide me with information on the cost of sherardizing relative to other galvanizing processes such as hot dip. I am assuming that it is a relatively small percentage of the cost of a part whether it be a bolt or a larger parts. Any help would be appreciated.
Sam Dunne
Engineer - Montreal, Quebec, Canada
Need a Sherardizing Service
(2001)
RFQ: I am looking for a Company in Canada or the USA that can offer a Sherardizing application to be applied to Spring steel.
Alan Parish
- Regina, SK Canada
outdated
similarly
similarly
(2003)
RFQ: I am looking for Sherardise Grade A supplier. Can anyone provide me the supplier who provide this service in Malaysia. Your reply is appreciated.
Thank You,
Jonathan BY Sia
- Muar, Johor, Malaysia
outdated
(2005)
RFQ: Hi,
I am looking for companies in Asia that would provide sherardizing finishing, any tips please?
Laurent Disdier
Architect - Hong Kong
outdated
(2007)
RFQ: We have specified the use of M24 10.9 grade bolts, nuts and washers to A490M, A563 and F436M respectively, to be used in the construction of the top portion of a very high building in the Middle East. It is intended that these be sherardised, but we are having problems finding a treatment plant to complete the sherardising. Are there limitations on the treatment process (e.g. size, temperature) that prevent this being done? There are several thousand items to be treated.
Hugh Cunningham
Engineering Consultant - Dubai, UAE
outdated
Ed. note: Current, active RFQs are now on our "Looking for a Finishing Service" page.
Need a Sherardizing Consultant
November 22, 2011
RFQ: Hello, we are a manufacturing company in the UK and would like to start up our own in house Zinc Thermal Diffusion or Sherardizing process .
Is there a consultant who we can approach to help get us up and running .
Regards.
Dick Kirk
Technical - Suffolk, UK
outdated
Ed. note: Current, active RFQs are now on our "Looking for a Product or Service for Our Finishing Shop" page.
Threads on similar topics include:
- Letter 8591, "What is Sherardizing?"
- Letter 18257, "What is Distek / DiAv-93 / Unstain 1500 Thermodiffusion Sherardizing"
ADD a Q or A to THIS thread START a NEW THREADView This Week's HOT TOPICS
Disclaimer: It is not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & DevicesUsed & Surplus
©1995-2017 finishing.com     -    Privacy Policy
How Google uses data when you visit this site.
